Hello I'm fighting the EAS monster and after 2 weeks of study, change the airsprings for new ones, rebuild compressor and two attemps with the valve block following all the info published by rangerovers gurus here.
I've got a system wich rises up ok (time and pressure), maintain the air tank pressure and rear springs weight without leaks (I've installed a pressure gauge).
Now the car goes down from front airsprings. It's not a calibration problem cause happens with levelling deactivated. I've observed that right side goes down quicker than left.
Could be the front right valve? Or maybe the NRV?
If the front left valve doesn't leaks this side has to maintain height, isn't it?
I'm becoming a little paranoid with the EAS renewal
