Range Rover P38. 2001, 84k miles.
A "whine" developed again in the area of my serpentine belt. I had similiar sound in 2009/10 and solved by changing cooling water pump.
It re-appeared a few months ago and I have been struggling to identify cause. A key sympton is that it is not noticeable in first say 5 mins of running but then it develops.
SYMPTONS
- appears to come from somewhere near belt area
- is present when car is in neutral.
- present only after a few minutes of running.
- do notice a smell of burning rubber or oil as well
CHECKS
- does not appear to be the engine....I took off the belts and ran engine for short time with no whine. When I re-installed belt a whine was present. (although I want to re-test that....just in case I missed something)
- replaced the two iders and the tensioner. no improvement.
- Alternator? No obvious issues. But just had the alternator tested on bench this morning..with no noise. However I left it with them this morning and asked them to run it for a while to see if bearing noice would come after extended running (temp rise!)...
- A/C compressor? whine is present when the clutch is engaged and not engaged .
- power steering pump. Slight axial play in that bearing (maybe 1mm) but no sign of radial looseness.
- tried new belt. I only left it on for two mins of running...actually thought it made whining worse! Put the old one back on.
Wonder if I missed something with the above checks?
That leaves
- the harmonic balancer....could that make a whine. Is there a way to check?
As you can see I am baffled and welcome ideas.
SYMPTONS
CHECKS
That leaves
