21 - 40 of 51 Posts
All fitted and working a treat. Much like the steering wheel controls, they freshen up the interior for very little money
I'm thinking of doing the same thing, mind sharing the company that you purchased them from. I have a found a few, my assumption is the product is the same just different sellers.
not a problem, see link below.
Think your pretty much spot on with the manufacturer of these (Zhifang) and then just different sellers
did you have to do any type of reset on of the switches? I ran into a problem with all but the drivers switch. seems the polarity is reversed on the others. when i go to lower the window it goes up but from the drivers switch it works fine. I swapped back in the original switchs and they worked fine. My switches are the ones with the illumination on the switch.
@HwnRR06
Hello, how are the window switches holding up? My OEM driver's side one is peeling on the edges where the black paint rides along the edge... I can't decide if I want to disconnect it and plasti-dip it (would look nice and I'm talented using Plasti-Dip/Good Luck in past), or to replace all the window switches like you did. Let us know how she's holding up both in operation and looks bro!
-Hams
Just ordered the steering wheel controls how do you install these? Do the original ones pop off or is there a screw like where the paddles are?
I used this video from PowerfulUK as a guide:
but this one is more detailed:
UPDATE: defective switches, seller is sending new switches.
Would like to update that after only a few months of using the window switches. A couple of the single units the switch has collapsed and now doesn’t function correctly. Will be removing them and fitting standards back in. Steering controls still working fine.
Usual chinese crap! :(
just installed the aircon pannel but i keep knocking the rotary dials on the new lcd when i move the gear stick.. do you have a solution???
I find that if you only move the stick partially forward it still engages reverse and doesn’t touch the dials. You technically don’t need the full travel of the stick for the gear to engage. Give it a try and see how you get on
Hi all, did an exterior and interior facelift for my 2016 L494 but many posted exterior before so I go with interior. Basically I change the factory screen to android, aircon panel to the lcd version with terrain mode, change out to 2018 steering with the new controller as well as all the window switches. Lastly as my car has the miserable factory ambient light, I add on other ambient lights to the car and control it via the screen. Oh ya. i also change the digital instrument display.
Here goes.
View attachment 302264 View attachment 302266
What's up guys, I have a 2015 range rover sport, got into an accident. Now getting a SVR compete kit. I did the upper and lower pulley for the supercharger and tune. I upgraded the SVR front seats. Anyone know how to code to get the SVR welcome screen on the cluster and radio. With SVR guages, to complete the look
can you tell us more how to changed out the instrument display? did you go from dial to LCD?
21 - 40 of 51 Posts
