41 - 51 of 51 Posts
That would be great but having a really hard time buying anything from them
rather buy from @EuroActive , they are based in the US and Justin answers things on the forum very quickly. I just ordered a set of touch steering wheel controls from them.
Thanks for the post! Great work. So I went ahead and bought everything to be able to install the new window switch pack on my L405 since L405 and L494 are the same design when it comes to those little things. Same thing here the cut hole in the door is a bit bigger for the new switch pack. So I used the old outer frame which was silver in my case to be able to support it. My only problem now is the pin configuration !! I thought it would be only three pins and I kinda be able to play around with it until i get it right, but the new switch pack I got has 6 pins sticking out, and im wording how many pins are sticking out from the new switch pack you got RRJon818 ? I have this suspension lowering button option on my window switch pack and this uses 3 wires and has a green connector as shown in the picture. Your RRS does not look like it has it and I kinda see it light up in the new one you have but I'm pretty sure it doesn't work. In addition, the window switches use another 3 wires and use the blue connector. So this is a total of six wires. I have no idea in what order they go or which 3 of those 6 pins are used to be able to operate window, door lock and mirror controls. Im searching around to find pin configuration for the new window switch or at least something smiller that would help as which one is power and which one is ground and etc.. RRJON818 your input would be highly appreciated. View attachment 287754 View attachment 287755 View attachment 287751 View attachment 287752 View attachment 287753
where can i byu tbis ? how much does it cost ? dows it have aftermarket ??
Hi Guys, I am contemplating this switch change but I have a question for the driver side part. I see two part suggested here LR113038 and LR099171. I check with Lrparts and it seems one is for car with air suspension and one is not. I dont think the switch allows for air suspension control right?
Then when I gave them a vin to check, they suggest another part LR123006. A quick google shows it is with folding mirror. Doesnt the first two parts have folding mirror? Or are the first two parts wrong?
Unfortunately this isn’t plug and play. Also the door cut out is larger on the older controls and would require a spacer. See set being sold on EBay:
A tech company in Russia manufactures the harnesses to be able to plug and play. But you would still need the spacer from them also and could purchase the switches locally.
Hi thanks for reply. Yes i forgot to clarify. I am just checking for the correct part to get for the window switch apart from the harness and adaptor needed.
is the part LR123006 correct for the driver window switch?
Sorry, that I’m not certain of. The eBay kit references LR099171. Good luck and follow up how it turns out. Would be great to see a full install.
Hi, I have got the carsystem kit but I need some help here. How do you fit the spacer to the new switch?
The top part is easy as it sit on the switch. But after dropping into the hole, how do you secure it from the back? It comes with another plastic part but it will not fit. Do you need to cut the two mounting part away?
also on the driver switch, the adaptor has a wire that says to connect to green plug hole 3. What does that mean?
Thank you very much.
Hey guys, was wondering if anyone ever tried to upgrade the window switches on 2014-2017 RRS to the newer style 2018 ones? Not sure if they are plug and play, but i just ordered the window switches and eager to find out how to do the upgrade. They may not have the same port on the back of it as the older ones do, so if not, then hopefully there could be some soldering done to the wiring. Let me know, thanks!
View attachment 285428 View attachment 285429
Hi
Hope you don’t mind me contacting you on here.
I saw you post on here that you successfully installed 2018 windows switch to 2014 l494.
I have upgraded my door cards on my l494 2016 with cards that have the new switches (like yours)
Everything were present and didn’t have to make adapters or anything else, HOWEVER SOMETHING ISN’T RIGHT BECAUSE THE LIGHTS ARENT WORKING. Im reaching out to you to see if you would kindly share information on how to make it work please .
thank you in advance and all the best.
I'm tired of the sticky window switches, is there an aftermarket plug-n-play product out there?
41 - 51 of 51 Posts
