5.0L Tensioner/guide replacement. Official zip tie method.
Results 1 to 11 of 11
Thread: 5.0L Tensioner/guide replacement. Official zip tie method.
    August 17th, 2004
    Cape Town, South Africa
    700
    I have just completed this tensioner/guide replacement on my 2011 L322 SC with 85000 miles on the clock by following the official JLR short cut method which uses a zip tie to secure the chain and it worked like a charm. I have come across a couple of threads on this forum and the Sport forum but thought I would add a bit more to assist and put peoples minds at rest.
    I followed the attached Land Rover Crankshaft Pulley Removal procedure and then the Timing Chain Tensioner - Engine Set procedures with a few of my own shortcuts. There were one or two coolant pipes that I did not disconnect or remove because there was no need and I did not replace the fuel lines as one is supposed to according to LR but basically did it according to the book. I also left the alternator in place.
    I was mistakenly sold a crank locking tool kit from the earlier 4.2 SC engine but I decided to modify it slightly and it worked ok. (It was one third of the price). The only down side in using this tool kit is it does not include anything to help with refitting the crank pulley which is a very tight fit.
    The bottom line is you need to remove what is necessary to get to the timing chain covers and a bit of common sense in conjunction with the manual will tell you what must be done. Once all the peripherals and the crank pulley are out of the way you remove the upper timing chain covers - left and right - and then the lower (not necessarily in that order). I fitted 2 zip ties to each bank in turn because I had read about breaking zip ties and the nightmare involved to put it right but as long as they are good quality you should be fine with one. Provided you have the crankshaft in the correct position as per the procedure. This removes any tendency for the cams to jump as they will be in a neutral position with no tension on any of the lobes. The guide on the left hand bank was not very easy to remove and refit but a little bit of persuasion helped. I had read that some had to remove the fixed guides as well but not in my case. It may have something to do with how tight you make the zip ties. Mine was not very tight because I could see how the tightness could affect the removal/refitting. The right hand bank guide slipped in and out with no persuasion required - it was very simple. I fitted new tensioners which are supplied with the plunger in a compressed state secured with a pin that is removed once in place and once it was all done I closed up and reassembled. Car is running like a dream now and finally I can put the hammer down and have some fun. I bought it with the engine rattle and have been nursing it pending this job.
    I have not listed all the steps because most of them are obvious and in the procedure but here are a couple of cautions.
    1. Fuel lines. If you do replace them it makes the job a lot more complicated because you have to remove engine mountings and various other bits and pieces. Land Rover include this due to the dangers of working with any fuel related parts and possible leaks so if you want to be totally sure you should follow what they say. But re-using the pipes it worked for me.
    2. Crank locking tool. The early version I used can be modified but not without the help of a good machine shop. You will be better off with the correct one. I actually plan on buying one soon because I have a few of these jobs looming.
    3. Upper timing covers. There is one bolt on each that is hidden and can make you a very sad person when the cover breaks as you try to lever it off. I very nearly shed a tear when it happened to me. Thank goodness for my parts car.
    4. The crank bolt is very tight and may have a left hand thread or right hand thread. This is easy to determine by checking the numbers on the bolt head. I managed to remove it using my 1/2 drive breaker bar with a 2 meter cheater lever but a 3/4 drive would be much better. Especially to tighten.
    5. I did not use the crank locking tool as per the procedure to lock the crank via the ring gear. This is just to temporarily secure the crank to remove the pulley inner torx bolts when shown in the procedure. There are easier ways to lock it.
    5. A dedicated puller is needed to remove the pulley and it remains very tight right up to the moment it pops off. There is no way that you can lever if off.
    6. The procedure states that the engine must only be rotated in the direction shown in the procedure using the refitted crank bolt as the means to turn the engine. This is a problem due to the left hand thread - it loosens the bolt when you try to turn the engine. So I temporarily fitted the crank pulley with just enough bite to enable the torx bolts on the inner part of the pulley to be used. Its obvious when you see it.
    7. I finally refitted the pulley by gently tapping it on by holding a large socket against the inner face of the pulley and carefully hitting it with a hammer until it was definitely on straight and moving gradually and then using the old crank bolt to pull it on. Finally swapping the bolts with the new one to fully tighten. The LR tightness is insane. I could only manage the 200NM followed by around 45 degrees. The procedure requires 270 degrees. Impossible with a 1/2 inch tool. Will be doing it again once my 3/4 drive 24mm deep reach socket arrives.
    In conclusion it does seem like a daunting procedure but if followed with care its very much a DIY job. I have done many timing chain guide replacements on the older BMW M62 motor fitted to early L322's and this is a breeze in comparison.
    No photos are included in this post because the attached manual sections show everything very clearly.
    Attached Files Attached Files
    P38 2002 4.6 Vogue
    L322 2011 4.4 TDV8. 2011 5.0 SC
    L320 2010 5.0 SC
    L319 2010 5.0 V8
    L538 2012 2.2.
    CAV GT40
    September 7th, 2016
    Boston, MA
    135
    Re: 5.0L Tensioner/guide replacement. Official zip tie metho
    Awesome information! Quick question: is there no need to replace the chain? On m62tu by the time the tensioner/guides give out, chains have stretched and need to be replaced because of all the slack. Is it not the case on the newer motors?
    2004 Range Rover HSE
    August 17th, 2004
    700
    I think it depends on the mileage of the car. High mileage obviously means more stretch but I cant say at what mileage this becomes a problem. One thing I did not look at is whether the chains can be removed using this shortcut method. Pity.
    The difference between this tensioner problem and the BMW problem is all of the components are still intact on this motor unlike the BMW in which the guides are normally lying in the bottom of the sump. So the slack in the chain is not much but enough to cause a rattle and obviously enough to destroy the engine when they eventually wear enough to cause the chain to jump teeth. On my motor using a pick tool you could lift the chain around 5 to 10mm away from the guide rail. But thats at one point so overall the slack was not much.
    High mileage cars may have noisy variable cam components as well as stretched chains so perhaps all the parts in the mechanism should be changed but once again that depends on the motor condition.
    P38 2002 4.6 Vogue
    L320 2010 5.0 SC
    L319 2010 5.0 V8
    L538 2012 2.2.
    CAV GT40
    FRESHMAN ROVER sowr's Avatar
    October 31st, 2017
    Big Bear Lake
    241
    Great job! I did not realize that the zip-tie method was an official JLR procedure, so that's good to know.
    Range Rover HSE 2010 (5.0L V8 NA) with Factory Roof Rack - Zermatt Silver, Black Interior.
    FRESHMAN ROVER dalek1's Avatar
    August 30th, 2017
    Palos Verdes Estates, CA
    39
    For those of us non-DIY type, can we get an accurate price on what the indie shops charge (or should charge) for the job? I hear anywhere from $3000 to $8000! I'm in Los Angeles area.
    2011 RR SC
    2014 F-Type S
    2006 RX400h
    2005 XJ8L
    2016 Prius
    January 15th, 2017
    Oklahoma
    71
    Outstanding, thank you.
    May 2nd, 2019
    Buffalo NY
    Thanks for the write-up, timing couldn't have been anymore perfect. My engine just through p0016 and p0018 codes.
    FRESHMAN ROVER naks's Avatar
    May 8th, 2019
    Stellenbosch, RSA
    47
    Thanks GT40!
    Sent from my G8441 using Tapatalk
    2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear
    2015 Range Rover Sport Supercharged V8 HSE Dynamic
    Defender Puma Workshop Manual: https://bit.ly/2zZ1en9
    Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO
    Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ
    SOLIHULL ROVER Mrmerlin's Avatar
    January 20th, 2010
    Philly PA
    1,870
    NOTE if after doing this job you still have the diesel noise you will need to replace the cam phasers.
    this requires the whole job to be be done again.
    I strongly suggest that the phasers be replaced along with the tensioners the guides the chains.
    Stan
    August 17th, 2004
    700
    While I do agree that replacing the whole lot may be a good idea on a high mileage vehicle, I think its an overkill on others. Noisy cam phasers may be a bit annoying but I think that the number one aim with sorting out the timing chain guide/tensioners is making sure that the engine does not get damaged when the inevitable happens. I have 3 other 5.0L vehicles in my yard with damaged engines due to the chains jumping teeth. 2 of which are destroyed and one may be salvageable. The damage has nothing to do with with cam phasers.
    If money and time are no object then definitely do the whole lot. And you might as well do the supercharger snout because it will be getting noisy sooner or later. And the fuel pumps and vacuum pump for the same reason. And a bunch of other components that will be wearing out eventually. The time and cost of doing the tensioner job is a fraction of the cost of doing everything. Having done the job once I am sure I could comfortably do the tensioner/guide swap in 5 or 6 hours provided I had all the parts and tools ready and provided I did not encounter any other snags along the way.
    P38 2002 4.6 Vogue
    L320 2010 5.0 SC
    L319 2010 5.0 V8
    L538 2012 2.2.
    CAV GT40
    August 17th, 2004
    700
    An example of what can happen when an engine lets go. I bought the car like this so have no idea what happened but I would have loved to have seen the look on the drivers face when it broke. (I doubt its related to the timing chain guide wear but you never know).
    5.0L Tensioner/guide replacement. Official zip tie method.-snap_005.jpg
    Thats looking down the plug hole with my endoscope. I guess the rest of the piston is lying in the sump or maybe even on the road somewhere. I have not investigated yet to see if the engine has any holes in it but I am sure there must be one or two. Car is a 2010 L322 SC with 40000 miles on the clock from new and is in showroom condition. Goodness knows how the previous owner managed to do that.
    Lucky I have a spare engine sitting waiting patiently.
    P38 2002 4.6 Vogue
    L320 2010 5.0 SC
    L319 2010 5.0 V8
    L538 2012 2.2.
    CAV GT40
  1. Fan Shroud Zip Tie Mod and Removal
    By 99Discovery in forum Range Rover Mark III / L322
    Last Post: February 25th, 2019, 05:58 AM
  2. 5.0L timing chain - zip tie pix?
    By mrpotatohead in forum Range Rover Mark III / L322
    Last Post: October 22nd, 2018, 06:36 AM
  3. Tensioner/Tensioner Blade Guide Differences for 10-13 RRS
    By Rovercharged in forum Range Rover Sport / L320
    Last Post: August 13th, 2017, 11:57 AM
  4. 99 4.0L Idler and Tensioner Bearings
    By rpage in forum Range Rover Mark II / P38
    Last Post: December 25th, 2007, 06:46 PM
  5. Hog Rings vs Cable Ties (Ty-Rap, Zip Tie etc).
    By dave-the-diver in forum Range Rover Mark II / P38
    Last Post: November 22nd, 2007, 10:02 AM
