I am having a minor issue issue with my 2015 SC. When the engine is cold (i.e., just started, not necessarily cold temp outside), the transmission shifts gears at a much higher RPM than when warm. Shift from 1st to 2nd often takes place north of 3000 RPM when the truck is first started. After running for 5 or 10 minutes, it settles back into a normal shifting pattern. It is not a big deal to compensate by the using the manual, paddle shifter when first starting it up, but it makes me wonder when there is a real problem here I should be addressing. What do y'alk think?
