G`day , when you say dash pod is that the entire dash , heater controls , switches etc does yours have ABS and do you wish to use the traction Control , i would imagine you won`t use SRS , will you use the smaller steering wheel ,would depend what you want as to how much of the wiring would be needed , do you know the instrument have a CPU ?
Or do you mean the part the has the instruments ?
I agree about the searching needed to find where things go and how they are connected or relate to each other .
We had an LSE Soft Dash which was replaced by the L322 the LSE had a fault with the aftermarket fuel pump and because it also ran LPG it had a few wires cook because here the petrol is wired to pump all the time on either fuel , the injectors are turned off on LPG.
There were wires melted under the bonnet , under/in the dash , along one side and all of the pump wire from the pump up to and along the roof at the rear quarter .
It didn`t take all that long to repair but it took hours and hours to trace wires and work out what they did and it wasn`t straight forward because the melted wires didn`t need to be part of the problem they only needed in the same loom or fastened to what had melted .
Luckily we also have a SE Soft Dash which was helpful when things didn`t make sense .
If there is an over all wiring diagram for a Soft dash i can`t find one even the Power and Earth distribution don`t have an over all they are piece by piece .
The L322 Flow type thing is much easier to follow and it does give an over all of the Power and Earth distribution so you can see what is common to what and how things relate and then can go to the specifics of what is needed .
The Soft dash one is nothing but hard , time consuming work at first i thought it was me being used to the old type and i`ve always agreed with " a poor workman blames his tools " but in this case i think it is the tool .
