Central Locking Control Unit
7.2K views 3 replies 3 participants last post by  jammez3
Hi Folks on the list of niggles to fix is the central locking on my soft dash. I think the driver actuator is dead as it's not doing anything on the test bench so I'm going to replace that.
I'm also having difficulty finding the control unit rave says it should be under the rh side of the fascia but I just cant find it! Any suggestions?
As far as I can tell it should look like this
On my 93 RRC, I had to replace mine - the old one would "go nuts" when it got humid and would lock/unlock randomly and for no reason at all…..bought a used on off Ebay for $35 bucks as I recall - it was located to the left of the steering column, kinda high up in that space behind the fascia trim. Once I removed that trim face plate, I was able to locate it easily - it's not a small box - measures roughly 4" x 2.5" more or less. Not sure where the heck they put it on the 95……..good luck.
