Please tell me this is not the dreaded timing chain? 😕
hmm, no, because:This is the correct part for JLR.![]()
Torsional Supercharger Coupler for 2009-2015 Jaguar, Land Rover, Range Rover 5.0L (Eaton Factory Replacement) - Superchargers Online
The supercharger coupler mates the front drive cover input shaft (also called the nose drive) to the timing gears that spin the supercharger rotors. It isolates the gears and rotors from high torsional inputs generated at the crankshaft due to cylinder-to-cylinder firing variations, primarily at...superchargersonline.com
Mine definitely has the electric bypass unit. But when I look for that part number on their site, nothing comes up.This coupler fits:
- All 2009-2015 Jaguar Land Rover (JLR) 5.0L engines WITH the vacuum bypass actuator
- 2014 – Present electric bypass units use EAT-360148
- Optional solid isolator PN: EAT-308858
yeah, did that a few months ago, no response. I've messaged them on the Insta, let's see.2014 – Present electric bypass units use EAT-360148
Thats a start. Email them 🙂
Solid Nyloil® Green Supercharger Coupler Coupling for Eaton
Upgrade Aftermarket Replacement Part
Oil-filled nylon (green color)
Oil-filled nylon contains liquid lubricant that is encapsulated during manufacturing and provides true lubrication at the bearing surface.
The material is suitable for applications where maintenance lubrication is difficult or impossible. In addition, there is no moisture adsorption. The upgrade coupling is designed for a long service life.
Suitable for the following compressor models
- Low friction coefficient
- Reduced "Slip-Stick"
- Low moisture absorption
- Reduces or eliminates need for lubrication
Suitable for/ Fits
- Eaton TVS Jaguar Land Rover 5.0
- Only 5.0 models!
- Does not fit 3.0
- Jaguar XK XK8 XKR X150 2009-2014
- Land Rover Range Rover Sport 5.0 2009-
- Land Rover Range Rover 5.0 2009-
TVS UPRATED COUPLER
The Achilles heel on the Jaguar and Range Rover TVS is the sprung drive coupler, if you have a rattle at idle it could very well be this. The coupler spring wears against the shaft until it breaks and badly wears the shaft as pictured. Our uprated coupler removes the spring from question and works on worn shafts without issue. Simply renewing for a sprung coupler will only end in the same fate. Our uprated oil filled nylon couplers start at just £38.
Thanks for the pics Naks... Glad you are getting her straitened out and didn't develop the dreaded engine clink... You've switched to LM for engine oil now too correct?This is what the old coupler looks like
Goodness Naks... Did you get the SC Coupler installed by now and Fixed All Ticks so to speak as of now I hope? I wonder if there is a Refurb-Kit or something to Re-Hab these Couplers? If they are Plastic Housed I wonder if this is something a 3D Printer can Replicate and then Re-Furb with a new "Upgraded Spring" and other hardware inside the Housing???after much to-fro with the dealership, we finally found the correct part, which oddly enough had to be sourced from the Jaguar parts bin: C2D60916, which is the 49.38 mm one.
