So I snagged me a Range Rover for $1000
4.2K views 19 replies 11 participants last post by  TheWojtek
#1 · (Edited by Moderator)
Yea you read it right. At the Auction, had been down there 3 years in the corner and ignored constantly over and over again. Even by me. I decided to inquire about it and it turns out the the Auction Higher-ups wanted it gone. They couldn't even figure out what was wrong with the thing, as they couldn't get it to start.
2011. Range Rover Supercharged 5.0.
I offer $1000. The take it under the premise that I take it immediately. A tow truck later and I have it at my house. Well, needless to say whoever their in house mechanic is, is either slow or lazy, because it was easy to figure out why it wouldn't start. Needed a new Battery. Checked the Oil and it was black as sin. Checked it's Coolant and that stuffs new. Was low on brake fluid. That is it. Drained the gas out. Put one in. 9 Quarts of some DUMB expensive oil from the dealership, topped off the Brake Fluid and since it wasn't detecting the key fob I put it by the column and she started right up. I let her run for an hour straight.
No overheating. No misfiring. No nothing. Doesn't even have the timing chain clatter I hear these things have and low and behold....she has only 61k mileage. Nice.
Why am I here??
Well, the right left Caliper on this thing driven until the caliper basically popped all the way out, and the rotor on the thing is literally as thin as a Penny. So I removed the Caliper, tested to see if it would go back in, turns out it does. With no issues. Changed the rotor, and back pads while I was at it. NOW....
I have brakes at the rear. And while the front brakes bite, they bite HARDEST on the second pump of the brakes. The Master Cylinder appears to be fine. No leaking, the seals are intact, no blackness in the fluid. Also I have the ABS Triangle, as well as the Orange "Brake" lamp lit. But it's holding fluid fine no leaks.
Do I need to do a full bleed of the system? A bleed at the ABS actutor? is this a sensor thing? Will the car electronically NOT send Brake force to the rear if it detects something is amiss??...any kind of insight would be great as this is truly the ONLY problem with the truck. I actually drove it around and while I can stop wit just the two upfront, for the upcoming winter days Id like the full control and power of all 4 corners working.
Sidenote: Is there a fuse or something I pull to check as to why this thing isn't reading the fob without me putting it on the column? I have no keyless entry functions whatsoever, but it works fine when I hold it up by the column underside.
Nice find and deal!!!
#5 ·
That's a kick ass score!!!!! The money you saved will go into the myriad of repairs it will need to bring it back up to par.
#8 ·
So, you jack it up, remove the rear wheels and have an assistant (wife?) tap the brakes and observe what is going on with the rear calipers. Or, take it to a good brake shop (maybe dealer) and tell them to fix it. After all, it ain't like you are going to be out a lot of money, in the aggregate.
Congratulations on a nice find.`)
#9 ·
That is amazing
I am simultaneously THRILLED for you (LOVE stories like this) and absolutely jealous as HELL. :D
#11 ·
Yep - start with removing the brake sensors one at a time to see which needs replacing (probably the one where you had rotor worn down all the way) - then do a regular flush/bleed (easy with pressure bleeder and a quart of Castrol fluid) ...if you still have abs light at that point you may need to take to specialist for code read and diagnosis.
Change battery in fob - said it come with second fob to try ? If not , might want to invest in spare key anyway. Next thing to check would be antenna on receiver under the column - if it is damaged that could also explain why it cannot read except at close range - but more likely to be your fob itself ....
#12 ·
I'll be posting pics soon, matter of fact i'll go outside and take some tonight. ALL 4 Brake sensors are done for, so I'll have to order 4. Im prepared for that, what I haven't done is a Bleed on the system. FOR THE SAKE of keeping things uniform and properly done i may take it to a Brake Specialist or the dealer and let them handle it.
So Far what im seeing is that there is NOTHING going to the rear Calipers at all, at the same time I know for a fact that when I did push the caliper back in and set everything back together it was not properly bled. Someone told me it has to be bled from the Caliper and the from ABS actuator, and that bleeder tool has been mentioned a few times I may just invest in that.
Pictures in a few moments guys!
#13 ·
I cannot speak for the petrol, Brembo vehicles but my RRS has only 2 brake sensors - front left brake only on the front and only one on the rear (not sure sure what side). They are not on all 4 wheels.
Garry
#19 ·
I had often seen the Truck and Ignored it myself. Range Roves typically get a bad rap as being unreliable over 50k and are avoided like the plague around here. They cater to a specific crowd i suppose. I myself had only seen it because I was coming to the same yard to buy a 2009 535xi and it was parked RIGHT next to the car.
I bought the 535 and just asked about the truck and I have a VERY good working relationship with the company and they practically GAVE it to me for that price but honestly stated that they didn't know what was mechanically wrong with the car, it came in not running and they never bothered to look it over. I figured man what was the worse? Even for 1000 if I parted it out i could make WAY more then what I spent. Didn't know once I threw the battery in there i'd get a full on Running truck with very few issues. COsmetically she is sound, I ordered the new Drivers Side Mirror and Front Bumper, once I get these brakes squared away im going to go about the rest of the suspension issues I'll be good after that.
I can admit to knowing very little about Range Rovers, I buy for performance and in that category Im satisfied thoroughly right now.
#18 ·
So it this a bad pick up? good? Compared to other models? Whats the difference between It and the Sport? Are the parts the same? I thought it was the same because it has the 5.0 Supercharged in it. Im VERY mechanically inclined but I will admit that my knowledge of Range Rovers is limited, I don't really know the difference between trim levels.
#20 ·
It's an upmarket model compared to the Sport. They share the drivetrain, suspension components and infotainment, but basically they are different platforms (Sport being a shorter LR3/4 with a posh 5-seater body, FFRR being a platform on it's own).
Again - not a trim level, but a different model. Still - a Supercharged will be fully loaded in both Sport and Full Fat models apart from some really fancy extras that are extras anyway.
Take a look on the excellent description for your car here: http://www.rangerovers.net/modelspecs/index.html and compare it to the smaller Sport.
Actually - it's even a greater find. A $1000 FFRR SC, I've honestly cried all night... ;)
