Hello Everyone,
Had my SE 400 since August. Everything has been great besides a bit of excess cabin noise from wind and road (I believe I can ask dealer to maybe do a road test and check if any gaps in seals ).
However within the last 2-3 weeks im noticing something (or at least I think I am seeing a difference) is that the ride height of the truck is a bit higher in the normal setting, and that when you park your truck up after driving and open the door it usually used to go into access mode and lower itself. I find it now even after returning to the truck after it has been parked for 30 minutes its at a pretty high ride height (almost more than normal setting). It is very odd that the truck just feels higher than it ever did at normal driving and it doesn't really go into access (low height mode) unless I click it (No the convenience setting in menu has not changed).
Also I used to (as much as I can and sitting in traffic, lower the truck clicking the button on driver side) and even tried locking in on the screen, but the minute it reaches some speeds it raises. Is there a software plug in tune that can keep the ride height lower? I am going to maybe getting lowering links and see if that helps.
