Hi, 2001 2.5 DHSE
Eversince my battery voltage dropped to 11volts and I replaced the battery (with 9volt battery backup) I am having problems with the passive immobliser :evil:
Can lock and unlock car, no errors on dash, tried both keys, engine check light comes on dash, engine cranks but not starting and battery new with 12.6volts
I borrowed a diagnostics machine and it showed "Engine Immobilisation / Alarm system on engine" I then read the immobiliser code from the ECM and re-entered this code. The fault cleared and the engine started, hooray I thought, until next day when I tried starting it and it didnt start. Borrowed machine again, same fault showing, re-entered immobiliser code, engine starts, 24hours later non starter. Right I thought :think: this time I found a section in the diagnostics software to "Disable Passive Immobiliser" yes just what the doctor ordered :thumb: so i gladly disabled it. Rebooted and checked and was disabled and engine was running, problem sorted
until next day :crybaby2:
Seems to me that its not remembering its immobiliser code and I disabled it. Now as I understand it when the key is inserted into the ignition, the coil around the steering colunm reads a code from the key and then sends the "all clear" to the BECM and the BECM sends the "all clear" to the ECU and hey presto engine runs. Where is the immboilser code stored? should I be looking at replacing the ECU? or the BECM? or should I remove them both to be tested somewhere?
Please any help or suggestions welcome as Im now into the second week of this problem.
