Here's a trick that can help identify what side the noise is coming from (although in your case you said it's coming from the right side) -
At about 40-50 miles an hour turn quite sharply right. If the noise goes away, the problem is probably on the right side of the vehicle (because by turning right, you are putting weight on left side wheels, and taking some weight off right side wheels.
This is how I have identified that my rear right wheel bearing needs replacing.
I haven't done the repair yet - I don't have the necessary 'press' to get the Bearing out of the hub. Probably requires at least a 10 ton press to remove old bearing and insert new. It is possible that I'll need a new hub if there's issues getting the bearing out. I've got a quote from a local shop that does this kind of stuff all the time, and it'll be around 3 hours / $300. May or may not need to remove entire knuckle assembly.
I have the time to fix it, so I'm considering buying a heavy duty press and doing it myself. Harbor Freight sell some that have actually got pretty good reviews. They also sell the various sized tools that are needed to remove and re-insert various sized bearings from different housings, suspension parts, etc.
I'm not sure what's involved with replacing the Front wheel bearings - Good luck.
By the way, my noise is a 'hum' rather than a 'clatter'.
