OK, I have read about RR coolant leaks until I can't see straight anymore but my leak seems different. I have the usual o-ring leak inside but the one that concerns me is the one that would leave the odd drop on the ground. Given that there are a few "wet" parts under the car before the liquid hits the ground it probably is a reasonable leak. I couldn't find the source so I keep an I on the level and top up when required. Once I came out to my RR (when it was cold) only to find a massive puddle underneath. I checked the level, topped it up. drove away, no leak... My mechanic couldn't find it, but we discussed the water pump. The leak is at the front of the motor and the control arms(? big rods extending from one side to the other) and front diff will end up wet. My wife now uses the RR and she had a BIG leak while driving, overheat etc. The resevoir is empty, top hose soft (empty) so I had it towed in. Would a water pump leak intermitently like this? I may have a leak at the back of the manifold and throttle body, but these are not the problem. My leak is much lower. My wife said steam was rising up from the vicinity of the oil filler cap but coming from lower down. Any ideas?????[/b]
