L322 battery dead , door locked (resolved)
4.7K views 14 replies 6 participants last post by  kevin_ra
Hello any idea how open door? Battery dead , key dosnt open the door . How can i open hood or door. . i dont want broke anything .
2003 L322
#2 ·
Key doesn’t open the door? What’s wrong with the lock cylinder? If you just meant it doesn’t function as a remote but have not yet tried the car key, pop the cap off next to the handle (where you’d expect a keyhole to be) and it will reveal the cylinder.
If you meant that this option doesn’t work either, we will need to wait for further advice...
#7 ·
No The key go in the hole , i can turn it but won't open the door. I'll call some mehanic who open locked doors .
Oh! So the link between the lock cylinder and the door latch is broken or disconnected? On modern cars I believe the interior handle should have its own mechanism to unlock the door. Now on a 1980’s Oldsmobile, maybe not.
#6 ·
In that case, there is a little side marker light on the front fender that can be popped out. You can then hook a charger to the positive wire, and the negative to a bare bolt elsewhere on the chassis. Allow the battery to charge an hour or so and the FOB should work.
Once you're in, I highly recommend opening up the door to figure out what is wrong with the key lock. These cars eat batteries, so having the key lock is pretty important.
