AC issue question
1.6K views 3 replies 2 participants last post by  ChipG
Fortunatly my AC is cold, but I have some issues with the vents. In the front the passenger(right) side vent has almost no airflow, the center and driver side seem ok, and in the rear the left has a little air, but the right vent has zero. Also, even with ac on the dash vents only, there is quite a bit off cool air freezing my feet. With the blower on high, the right side unit is definatly working by the sound, but there isn't as much going on on the left side(by the sound, anyway). I'd like to see if anyone has any ideas on what is going on before I dig in to explore. Thanks!!
I was thinking the left blower wasn't working. Does each motor feed different vents?
#4 ·
Ok, left blower wasn't working. Pulled the fuse and it was good, but when I restarted the car it started to make a whining noise, then after some cleaning and lube it runs free now :clap: . The right rear vent still has no air :think: , but everthing else is, well, double :dance: . I found Leftlanetruckin's post and that helped a lot, so thanks for sending me that direction
