2002 Range Rover HSE 4.4 V8 Petrol (BMW Engine)
Hi
Wonder if anybody could help me please.
I was in the process of changing the timing chaing gides after I found the best part of them in the sump.
Unfortunatly I did not keep the correct pressure on the main timimg chain and it has jumped teeth.
For some unknown reason I had not put the engine to TDC before starting, I had decided to do it later Doh.
I now have the problem that the pistons are out of time with the camshafts, I know this as I have got the crankshaft to a point where it will not go any futher, it got to that point gently and no force was used to move it on so I'am hoping no damage has been done .
I can back the crankshaft up until piston 1 is TDC and get the cams for piston 1 with the valves closed but my question is when piston 1 is TDC on bank 1 what should bank 2 be doing.
I have read a lot of the info for replacing the guides but cannot find anything that guides you to setting the timing from basic.
Help would be appriciated, if anybody has links etc.
Tim
Hi
Tim
