Hi,
Someone have a clue why land rover just put the twin rear exhaust in there? That is not a real twin exhaust (that actually would make sense on a V8), it's only a derivation made after the central box, and worse then that, the front section of the exhaust have the same diameter on both systems and uses a T-Shaped connection between the rear boxes instead a Y like should be.. I refuse to believe that LR just put 2 rear boxes in there to look good..
I'm asking because I thinking to convert my to a single pipe (using a rear exhaust but probably cutting out the box). The problem with the twin pipes for those U go offroad, besides the clearance to the ground, is that the exhaust don't create sufficient back pressure on both sides and if you enter backwards on the mud you will end up with 1 pipe clogged.
what do you guys think?
Regards,
Regards,
