Third brake light question
13K views 5 replies 3 participants last post by  arby
Hello
06 rrss
I recently noticed my third brake light in the wing is not working. I looked in the owners manual and didn't find much info. Do these just go out? How hard is it to replace? Any troubleshooting tips?
Dan
#2 ·
You have to remove the spoiler to get to those LED's. Too complicated for the average Joe to do, so the Owner's Handbook doesn't include instructions. Here is the section off the shop manual. Have you checked the fuses yet?
Exterior Trim and Ornamentation - Rear Spoiler
Removal and Installation
Removal
CAUTION: Always protect paintwork and glass when removing exterior components.
  1. Disconnect the battery ground cable.
    For additional information, refer to: Specifications (414-00 Battery and Charging System - General Information, Specifications).
  1. Open the liftgate glass.
    • Remove the 2 Torx bolts.
    • Close the liftgate glass.
  1. Open the liftgate.
    • Remove the 3 nuts.
    • Close the liftgate.
  1. Remove the rear spoiler.
    • Disconnect the electrical connector.
    • Disconnect the washer jet hose.
See post below for stoplight removal and installation
Spoiler Installation
  1. Install the high mounted stoplamp.
    • Install the Torx screws.
  1. Install the washer jet.
  1. Install the 2 clips.
  1. Install the spoiler.
    • Connect and secure the electrical connector.
    • Connect the washer jet hose.
    • Tighten the nuts to 10 Nm (7 lb.ft).
    • Tighten the Torx bolts to 25 Nm (18 lb.ft).
  1. Connect the battery ground cable.
Remove the stoplamp on the spoiler to access the LEDs:
Exterior Lighting - High Mounted Stoplamp
Removal
    For additional information, refer to: Rear Spoiler (501-08 Exterior Trim and Ornamentation, Removal and Installation).
  1. Remove the high mounted stoplamp.
    • Remove the 4 Torx screws.
Installation
