Sunroof Question
1.5K views 6 replies 4 participants last post by  Jnz
Hi All,
I have a 2013 Range Rover Sport, HSE Luxury and had a question about the sunroof and associated water leakage I'm having. The dealership is telling me that a little water leakage via the sunroof is normal in the RR sports, and that it's designed to capture water in a tray just below the sunroof and drain it out through tubes built into the car. And that as long as it's not getting into the vehicle - then they state that everything is as it should be. Water isn't getting into the car, but water does gather in the train. That sounds crazy to me, at least the piece about leakage being normal and the sunroof not keeping water out. I've never had this issue with other vehicles (non RRs) and was wondering everyone's thoughts on this. Should I push the dealer to replace the sunroof, or are they correct?
#4 ·
I'm curious about this, what is meant by water leakage? Water coming in after washing or a storm when you open the sunroof, or water actually coming inside, and soaking the headliner? Mine seems fine, water will come in after a wash or rain when I open the sunroof, but every car or truck I've owned does this. I do know the Discos had a more prevalent issue where it was in fact soaking the inside of the car due to poor/clogged drainage tubes.
#5 ·
In this particular instance for me, it didn't soak the headliner. I just noticed water had come in and gathered in the tray just below the sunroof. Again, according to the dealer water finding its way in but then finding its way out via the tubes built into the car is normal. According to RR dealer, the sunroof is not designed to be a perfect seal.
#7 ·
All of the sunroofs I've had have had some kind of drainage system with them. Some designs are more prone to clogs.
With the RRS, one thing to make sure if you're getting a lot of water in, is whether the glass is properly aligned when closed - it should be just slightly higher than the roof, so that water doesn't pool on the glass. This reduces the amount of water that goes into the drains, making it less likely to have problems with the drainage system.
