Hi all,
As it says is there a better relay out there to replace this relay :think: I'm looking for some alternative as all my spares are now shot /
They get a hammering by the HaVac blowers RL6 and 7 so i have been sussing out an a alternative relay with hopfully a better switching current. :think:
The cheaper replacement Tyco V23134-b52-x130 ywb 10027 is the Siemens V23136-B4-X7 AMR2548 Replacement
These are a Single pole normally open with Suppression S.P.N.O Relay
Does anyone know the Max switch current break and make off both of these relays
I found a Bosch relay P/NO 0 986 332 041 has a Max switching current - Break on/off 90A/40A
Max switching current - Make on/off 200A/60A
The Tyco replacement for this Bosch relay is a V23073-BI005
Don't know if its a plain relay or with suppression
The Suppression is a resistor / or a diode across the coil what does that do :?:
If this has already been disscussed , i appoligize as reading 1320 posts on relays ain't my way of doing research. :doh:
I know a lot of P38 owners would like an alternative longer life relay theres nothing in the main problem site only a fuse box fix so just asking!!!!!!!!!!!! :shhh:
