When I pull the lever to dispense the wiper fluid it doesn't work on the rear window however it does work on the front. Any help on this issue?
Long shot here - can anyone point me to the steps to remove the interior upper tailgate and upper trim please? I don't want to get anything wrong...The washer fluid goes through the rear wiper motor, which has a tendency to allow grease into the washer fluid passage, clogging both the motor and the jets in the arm. You can pop off the interior upper tailgate, upper trim(the clips are delicate, use care) and disconnect the hose to the pump to ensure that's where the problem lies.
Sometimes they can be cleared out, but sometimes you will find staining on the inside of the upper tailgate trim, which means the pump itself is leaking washer fluid/grease, and will require replacement.
