We need some help. About 8 months ago, my RRS coolant outlet flange broke while I was driving. I did a bit of a hard acceleration and all of the sudden smoke started coming out the front. I pulled over and saw that it was just coolant leak and was able to make it the rest of the way back home. My dad is a mechanic so we ended up just replacing it ourselves. Anyways, after successfully replacing the coolant outlet flange, our car started overheating. To make it a long story short, after replacing a bunch of parts and doing a couple things to it, it’s still overheating. Here are the things we’ve done.
A thing I’d like to mention is that every time we replace a part, we always vacuum fill it with coolant. 2/5 time that we’ve replaced a part and done this, we got heat back but it still eventually overheated.
Another thing I feel is important to mention is head gasket sealer. Before we replaced the first part on the car (coolant outlet flange), we waited about a month before we actually did anything. Every time we start the car up after that (for about 2-3 months to work on/test the car), there was always the light/medium smoke coming out of the exhaust. I’ve seen blown heads exhaust smoke but this didn’t look like it. Anyways my dad eventually decided to add head gasket sealant to it and it stopped.
At this point, we’re thinking it could just be the head but wanted to see what you guys think it could be.
- Replaced the water pump, once with an aftermarket and a 2nd time with OEM.
- Replaced the thermostat
- Replaced the coolant temperature sensor
- Flushed the heater core
- Tried bypassing the heater core
- Replaced the coolant outlet pipe (we saw smoke coming from here too and common overheating problems related to this)
- Replaced the oil cooler (shop recommended us to do this)
- Tried vacuuming air out of the cooling system and replacing it with coolant
- Tried burping the cooling system
- We used a combustion checker and it stayed blue
- We performed a leak down test and it indicated no leaks
