Problem with android 10.25
2.6K views 2 replies 3 participants last post by  W84IT
Hello Everyone, I’ve installed the android stereo, worked well for a while but now, CarPlay is going crazy, when I try to connect wired, it’s not charging but connects on and off, it’s say accessory may not be supported, I’ve tried several different OEM cords nothing works, now my screen for my original OEM screen has shifted to the right this was after the CarPlay update
281794
ATTENTION:
  • Please visit www.androidaftershock.com to watch the install and setup videos before installation.
  • Your OEM display MUST be set to AUXILIARY to hear audio from this Android unit.
  • There may be some noise from the AUX input if your OEM volume is turned up without any audio playing. Simply turn the OEM Volume all the way down and turn the Android volume all the way to max…then you can increase the OEM volume to your liking without hardly any noise through the AUX.
  • If your screen is off center, go to the Android Setup menu…select Version-Factory Set-enter 666666-Host Video Source and select from 1, 2 or 3 until your screen is correct.
  • If your steering wheel controls are not functioning properly, go to the Android Setup menu…select Version-Factory Set-enter 555555 and select from 01, 02 or 03 until your steering wheel controls are working properly.
  • (note: some steering wheel control does not work with Android Auto)
  • Some of the side buttons will not function with this Android unit…park assist for example.
  • (note: temperature display will be dim in daylight conditions due to the sensors on the side button packs now being hidden away in the dash for the install.)
  • Dual view screen will not function with this Android unit.
  • If the preinstalled apps on your unit are not functioning properly, update or reinstall the apps.
  • If CarPlay is not functioning properly, update the AutoPlay app software.
  • If you have done all the above and still need assistance, please call or text 760-625-3477 anytime between 09:00-17:00 Monday-Sunday
