21 - 40 of 126 Posts
How do you select Waze or Google Maps onto your dash display, the only option I seem to only have the Range Rover map option which isn’t graphically good.
I am able to get JLR Maps or Apple Maps on instrument cluster when Apple CarPlay is active, not been able to get other options yet
I just updated to IOS 18.4 so will see if that makes a difference
I’m not 100% sure yet. I’ve been trying to recreate this in other vehicles.
I did update the BCM in my 25MY D110. My wireless charger works better (still sucks) too. So I’m not sure if this had anything to do with it.
hmm I don't have it on my MY25 P400. I see focused, dials, and map and under dials, its the standard 2 dial layout. There is no single layout. Mind sharing what menus you go to through the steering wheel buttons to get to this layout?
We have this on our RR's. There are 3 options for the driver display. 2 Dial (Standard look), All map display, and the one dial center with radio left and map right. It does not look the hard 3d dial on the Defender ours have a fade soft look. The best way to swap this look easy is to go to the ALL SETTINGS / APPS / The click on the DIAMOND quick access button options. It's the settings for the diamond button on the steering wheel. Once you click on it in the settings APP window you can choose what the button does for quick push or long push. Lots of options for each and one is change driver display. If you choose that you can just hit the diamond button on the wheel and it cycles thru the driver display options quick and easy. I have Waze 4.5 but not the iOS 18.4 yet. Guessing he has the Beta option on his phone. So mine still does not show Waze yet.
I think the "one dial center" that you menion is called focused mode? Can you check what it is called under display layout? Below are my options under "Display Layout" and when I select Focused, I get something similar to what you explain but with digital speedometer not analog dial.
Yes, that's the single dial we have on our RR's. Same setup as the Defender but a different design look. The defender's look is more military I guess ours is more classy....:LOL:
ah yea. So to my earlier note, the photo that was posted in the parent post is not a Range Rover, it is from Defender
Yes, but the same main PIVI software as far as I know. The display looks are just cosmetic design styles. The RR SV has some different displays vs SE etc. I dont have Beta active on mi iPhone so I dont have 18.4. Once that is updated we can test to see if that makes the Waze update work on the LR vehicles. The poster above says he is running 18.4 OS.
