How often should the PCV valve be replaced?
Storey Wilson's PCV/CCV/OSV valve info was on the 2003-2005 BMW M62 engine and is spot on. That engine, if you research it, is plagued with a poorly designed crank case vent system that should be inspected and replaced often. In colder weather, if the system is not 100%, the mixture of oil and water vapor freezes inside the PCV valve. That causes over pressurization of the crank case and typically results in a leaking passenger side valve cover gasket. Do a bit of research and you will find this.I was also misled by a YouTube video by Storey Wilson. He’s the guy who sells the software for the gen 3 range rovers. I thought he was worth listening to because he sells the software, when he said pvc valves should be changed every 30,000 miles. I disagree now.
....They are not going to blow your gaskets
A leaking valve cover can cause rough idle/lean codes if it is allowing unmetered air to enter the intake through the PCV valve.The idea valve cover gaskets could cause lean codes made no sense to me
It is quite rare that any aftermarket part is better than the OEM part. I would not trust a chinese knock off PCV valve. I had an experience where I purchased what were marketed as OEM PCV valves for the 4.4l AJ V8 and turned out to be knock offs. The new PCVs resulted in reduced performance messages on the dash. Bad PCV valves can result in excessive vacuum which pulls oil into the intake. That oil can hydrolock cylinders under certain conditions causing engine failure. Not worth the risk to save a few bucks.Hopefully the aftermarket PCV valves are made better than the factory ones and I won’t have to replace it again
Nah. The mechanic was purely trying to rip me off. There was absolutely nothing wrong with the valve cover gaskets. I do all the work myself on my vehicles also. I’ve got the 2005 L322 with 225,000 miles now. Took that to another independent rover shop and he might as well have been looking into a bush. Had no idea or interest in the vehicle. I told him the alternator was not the issue and it had been replaced twice already so he decided to lie and say it is overcharging. It was not. Got the car back in exactly the same state I gave it to him in only with a 3rd alternator. These rover mechanics charge a lot because they haven’t a clue what they are doing. Finding a competent one is the same as finding a competent anybody in anything. My mechanic of 20 years works on ALL vehicles and is very successful. He knows the 2005 L322 is nothing special. It’s just a vehicle like anything else. A bad PCV valve that throws a lean code is not going to result in a failed valve cover gasket on the L405. That’s just dumb. I honestly think they came to that conclusion by reading posts online. I agree the Chinese PCV valves are a bad idea. As I stated I purchased multiples and the strength of the rubber varies. The one from Atlantic British matches the OEM.Storey Wilson's PCV/CCV/OSV valve info was on the 2003-2005 BMW M62 engine and is spot on. That engine, if you research it, is plagued with a poorly designed crank case vent system that should be inspected and replaced often. In colder weather, if the system is not 100%, the mixture of oil and water vapor freezes inside the PCV valve. That causes over pressurization of the crank case and typically results in a leaking passenger side valve cover gasket. Do a bit of research and you will find this.
Really should edit your post, he does know what he is talking about as any M62 owner is well aware. Further, his software did serve a purpose and was helpful to many.
Regarding dealerships, my experience is that mechanics do things in a manner to minimize callbacks - They don't get paid for doing the same job over again when it's not right the first time. They will quote replacement of any items that might lead to a callback, hence the suggestion of replacing valve covers. I'm sure an honest mechanic would verify it does indeed require replacement once removed. They also don't want to have to stop work and call the customer to approve replacement or wait for unplanned parts to arrive. You as a customer don't want additional unexpected expenses beyond what was originally quoted, especially items tacked on to your bill while your car is torn apart making it difficult to say no. That's just an experienced mechanic preparing you for the expense up front, experience they gained the hard way likely from a callback. The customer should be happy that they were only inconvenienced once to have it repaired properly the first time.
I have adopted a similar methodology when doing the work myself and personally don't like anyone else touching my vehicles. If I'm going to remove a part that will likely fail within a year or two in the process of doing another repair or that I have good access to while performing another repair, it gets replaced within reason and where it makes sense economically. Replacing the PCV valves as proactive maintenance on the 5.0 SC were a perfect example and met all of the criteria while doing the timing chain job - They were likely to fail in the near future, access to them was very limited once the SC was installed and economically it made sense for under $100.
I completely disagree with klf4000's opinion on Storey Wilson's knowledge on the M62 era L322 and believe he must be completely ignorant and uninformed about the M62....
im not sure how Storey Wilson blames freezing for the failure of gaskets in the engine. How long does it take for the PVC to thaw after an engine fires up? 10-15 minutes tops? His 30,000 mile replacement recommendation is excessive. Id agree at 50,000 but 30,000 is way too early, in my opinion. I also don’t know how you explain his software being in UK terms such as “petrol” engine. I don’t believe it’s his software. But these are all my opinions, of course. If anyone feels paranoid about PCV on the L405, changing them out at 50,000 miles will ensure they are always tip top...
This is the worst thing that one can do to a Range Rover or any other high end brand. One of the reasons they get such a bad rap is due to people who think they know what they are doing, working on stuff that they have little experience with. It almost guarantees to cause more problems for the future.The best thing anyone can do that owns a rover is find a mechanic that is NOT a rover mechanic and knows they are just cars. No differnt from any other vehicle on the road.
