P530 what's your mpg?
5.7K views 57 replies 19 participants last post by  red carrera
Curious- what's your mpg?
Predominant city driving. Abysmal 12mpg. Thought it'd be closer to 15
#2 ·
That's crazy. On my 461 First Edition 530 I routinely get 16-19 around town. If I'm on a lonely country road it's at 20 consistently.
I drive it exclusively in dynamic mode. It gets you to higher revs quicker with less throttle input which lands you in a high gear where you need to be.
Pulling my car trailer on the highway - then I'm stuck at 11 all day long.
#11 ·
I don’t have a P530 but had X7 M60i which has the same engine and most of my driving around home is traffic lights, stop signs etc with average speed of around 15-20mph. I got 8-12mpg tops! This is the reason I went with P400. Got sick of having to refill the tank so frequently and won't get another V8 as my daily. Also mpg will get worse during winter so brace for that.
#23 ·
I went and pulled out my driving data from InControl, and filtered for long trips and removed anything that started from home. This is the chart: essentially P400 MPG for highway driving.
Y Axis: average speed in MPH.
X Avis: average MPG.
Label on each dot: Duration of trip.
Enjoy. View attachment 333008
This is a great chart! Thank you for sharing
#34 ·
I don’t think the AC Music etc would have any measurable effect on mpg. I’m in Texas myself, mostly the AC is on, rarely heat. I have the heavier seats, full size spare etc as well.
The tires for sure have an effect. Did you update to heavier rims?
I've got '22 rims, that's what it came with. the tires are definitely impacting the MPG, but also, it wasn't that great to begin with. weird. I'm encouraged by what you all are getting, wish there was a way to get my MPG up a little too.
#41 ·
The steps on a browser:
  1. Go to My Land Rover InControl and log in (same credentials you use in the car screen)
  2. Click on 'VIEW ALL JOURNEYS'
  3. If necessary modify the dates in 'Show Journey From XXX to YYY' and press search. You will see a table of journeys that show From address, Start Time, To address, Arrival Time, Duration and Distance.
  4. Each journey is from the time you start the engine to when you stop the engine. If you click on a single journey you will see a map of what route you took and more detailed data. It's actually a bit concerning how much data is gathered.
  5. Select the journeys you care about by clicking the box on the left of 'From'. In your case - you would need to look at your fuelie log to see the date & time of two fuel stops and select all the journeys in between
  6. Scroll down to the bottom of the table and click 'EXPORT SELECTED' and you will get a download of a spreadsheet. This will have the detailed data of all the journeys you selected.
  7. See post #22 in this thread - I created that plot by pulling out all my journeys from the time the car was delivered, filtered out only the ones that are longer than 30 minutes and average speed of 50 MPH or faster, to plot highway MPG. I assumed the InControl measurement of MPG is correct - but that's not necessarily true.
#45 ·
I have a 25 p400 on the 22s all season oem tires, and from ny to nc 70mph I see 27 mpg, and around town long island 21 ,I drive very easy and try and keep my driving 95 pct or better according to the vehicle tracker and thats in comfort mode because whenever I try eco mode the car boots me out after 20 minutes or so and puts me in auto mode the dealership said thats normal not sure if it's true
