New Amplifier fitted , upgrade , no sound
1 reading
2.6K views 4 replies 3 participants last post by  Muny say
Hello all.
An update….. please help any more info….
I posted earlier about fitting a new amplifier.
My old amp was a HK HIGH 12. It stopped working so I replaced it , thinking about going for an upgrade to a HK PREM 16. All connections the same. I know the PREM 16 is more speakers , which I may fit later , I believe certain sounds may only be heard through MID speakers. But ….
I have done a software update on the car and also updated the CCF.
Still I have no sound.
All the systems ( radio , cd , iPod , sat nav , phone , reverse camera ) all work.. but no sound…. Any thoughts?
Thank you.
#2 ·
I know you have done this a hundred times but sometimes we over look things...check fuses, wiring looms for cracked casing, earths? or any other connectors you have done from your install.
I didn't see your other thread...so i will ask you is it a new amp or new to you?
Hello Googs, thank you for the reply.
The old amp , sound crackled for a few seconds then I had an electric burning smell from amp which after was very evident with amp, could smell it. The 40amp fuse in engine bay blew , which I replaced. The new amp is an upgrade High 12 to Prem16. Which I purchased from a scrap dealer. It is quaranteed for a year with them. The new amp is about 6 years I think.
Yes I checked fuses and wire looms etc. All looks perfectly normal. The old amp electric connectors and fibre optic all look OK and connected fine , same sockets on amp.
The CCF has been told of new amp and software updated.
Even if it is that I'm missing speakers , surely some sound should come out of the existing ones.
Could though their wiring be different on new amp......
#4 ·
Thank you.
It's all pointing to the second hand Amp you purchased or the wiring that the blown Amp come from.
Did you plug a scanner in ? did you bring up a code for the connection or Amp?
