L460 Leather Packages
5.2K views 6 replies 5 participants last post by  alidonkaka6
I’m specking my P530 and am a bit confused what leather package to go for. In other good news, the dealer said that order slots are being determined on the 10th!
Curious to see how everyone else specked their order.
1. Windsor vs. Semi-Aniline leather. Is it worth the upgrade? I wasn’t planning on doing the message seat option, so it would add $3,500.
2. SV Bespoke Full Extended Leather. What does this add? In particular, would the airbag cover not be leather without it. Also what does the door top roll cover? For $1,500 it might be worth it.
#2 ·
To save money on my V8 build, I'd be sacrificing the semi-aniline leather package first. It's very misleading anyways as it's not just $1850 and almost double instead.
More leather is more important than improved leather, especially since critical places like the dash and steering are not leather without that 1500 package. The build tool previews are also very misleading as it doesn't reflect that, and shows extended leather by default so less people are likely choosing that option only to eventually get a plastic steering center.
I'm between a fully decked out i6 and a v8 with some options shedded (semi-aniline, fridge, etc).
#5 ·
Correct me if I’m wrong but The current l405s all came with the steering wheel airbag cover in leather. It was only that L494 Range Rover Sport that had the plastic airbag cover (unless you went with an ATB). Kind of shocked to see the new Range Rover being down graded to a plastic airbag cover as standard.
#6 ·
Correct — to my knowledge, all US spec at least from 2016 and on were leather. My guess this is due to the "less is more" mantra and people may want non-leather options, so they went with more earth friendly plastic* for the base. That opens up a whole other conversation of is plastic better than leather for the earth — e.g. microplastic pollution, etc. — I know, it’s complicated.
* not sure if they use the same plastic base cover wrapped in leather or if it’s the same frame just wrapped in a synthetic fabric.
