Newly acquired 2011 L320. 115k on the clock. Appears to run fine on cold start up. Once the engine warms up it slowly begins to run rough to the point it will stumble (obvious misfires) loss of power and rpm return delay.
I have completed the following for routine maintenance and and in attempt to address the issue.
1. Immediate oil and filter change
2. New PVC
3. Air Filters
4. HPFP both replaced new
5. New plugs
6. New coils
7. Confirmed no vacuum leaks
8. Coolant flush
9. Thermostat
10. Fuel pressure sensor
OBD codes misfire on cyl 2,4,6,8 and 5 and fuel rail pressure low.
She always starts up well as long as she's cold. I suspected coils and plugs might solve my issue but no although plugs were shot and a couple coils were suspect on multimeter. I have an P38 I know inside and out but this is a different animal. My obd is a simple scanner with limited real-time data. Fuel pressure seems erratic but I don't know it should be. jumps form 200, 400ish at idle and settles some then can jump to as much as 2000ish with acceleration.
I am leaning injectors more gut than any empirical evidence.
Any help with comments and suggestions would be appreciated?
2. New PVC
3. Air Filters
5. New plugs
6. New coils
8. Coolant flush
9. Thermostat
