To the original poster; headlamp assembly is adjusted as an assembly. You cannot adjust low beam without adjusting the high. All adjustments to headlamps should be made in low beam position. If after this adjustment, you feel the high beams are too high, I would suggest inspecting your bulbs and the headlamp assembly to see if everything looks correct and intact.
I see a lot of comments about LED bulbs on here. While I am not 100% against them, I would like to point out that factory headlamps are designed to put out the best light output with the bulbs in them as installed at the factory. Meaning, you can try replacing an HID or Halogen bulb with an LED and you may and probably will get brighter light. However, it is the quality of the beam output that can be suspect. The reflectors inside our lamps are designed for the bulb from the factory. As soon as you put an LED or HID in place of a Halogen, you have now changed the position of the bulb and therefore how it reflects inside the headlamp assembly. With HID bulb conversion, this is almost always a terrible idea, as it results in light scattered all over the road except where you want it. With LED's they can sometimes be adjusted, rotated and tuned in to make work, but after every conversion it is important to reaim your headlamp assemblies.
In case you cannot tell, I work in collision repair, and I see people make this mistake all the time, and it is rare that the headlamps put out the quality of light they wanted. IMO, you will not get a better headlamp than the OEM headlamp with the OEM bulbs. In all the years of me installing and aiming headlamps, I have yet to see an aftermarket option that was as good as what was provided by the factory. Which makes me circle back the the original poster and his problem. Recheck your bulbs, make sure they are original equipment, and make sure they are seated and installed correctly, then reaim lights on low beam. If everything is correct, your lights should be in good shape.
