Front License Plate Mounting Options
31K views 54 replies 32 participants last post by  Kev12
Hi friends. I'm currently not running a front license plate for aesthetic reasons but I'm getting too many tickets for it. In my previous state it wasn't a big deal but here it is. I'm curious if folks have found creative solutions other than drilling holes into the front bumper. It doesn't look like there's an exposed tow hook on the front that you can mount an adapter onto. Thanks.
#48 ·
I'm running without it also even though Washington state requires it. Haven't had any problems yuet. Dealer doesn't like installing the front plate but also make you sign a statement acknowledging it is required.
Anyway...
3M make a double sided tape that would probably work. VHB tape which you can find on Amazon and probably at Home Depot. A lot of the air conditioners you see on top of RV's going down the road are stuck on with VHB tape....IE no screws, bolts et cetera so it should be able to hold a plate in place.
#50 ·
That was probably me who posted about it. Have had for two years, works well. Two screws underneath and there is a quick pin to pull to remove the front plate. Slide plate and pin it back in and now you have your front plate. Nothing is visible when removed unless you look under and see the small bracket. No holes In front of vehicle for the next owner.
