Coolant leak, Battery light and power steering failure All At Once
Hello, I really need you guys help...
I have a 03 HSE that i have had for only about 6 months. Two days ago i left the Range running at the gas station and while i spoke with someone, and when i returned to the car I noticed that the battery light was on and the temp gauge seemed to be climbing... At the time i thought the car had just turned off but then realized that it was still on.. I then turned the car off and back on and everything immediately went back to normal, even the Temp......
Fast forward to yesterday, No running issues but i did smell what seemed like Antifreeze for about 30 seconds or so (i would say this happened maybe 3 times), I did check the temp gauge whenever i smelled antifreeze but there was no sign of overheating... so as a result I kind of blew it off as possibly being some other vehicle that i may have been catching fumes from.
Then tonight, As I was just about to pull into a driveway when i felt the power steering get very stiff, I then noticed that the Battery light was on and the engine was starting to overheat... I checked for any kind of fluid leak coming from under the truck (nothing), but i could clearly smell the antifreeze when i opened the hood.. I just couldnt see where it was coming from, and sense there was no leak from the bottom i couldnt tell what really was going on... I then let it cool off for maybe a half hour and still didnt notice any leak...
I then started the Range and noticed that the battery light and power steering was still failing.. So I thought id take it around the block before i called a tow truck just to see if it would correct itself like at the gas station... I then got maybe one block before the power steering came back to normal and the battery light when out (they seem to fail or work together).
Then after about a mile,.... you guested it... the Range started smoking from under the hood and i could clearly tell it was that antifreeze on the engine type of smoke. I then pulled over and noticed that it had finally sprung a leak, but I still couldnt tell exactly where it was leaking from, If i had to guess i would say the lower passenger side of the vehicle sense that is where the flow seemed to be leaking from. I then let it cool and added Antifreeze which allowed me to be able to make it home (battery never died).
I am really new to these vehicles, but i suspect that a hose has blow or something similar, But im puzzled to why the power steering and battery light would come on... My best guest tells me that maybe the Serpentine Belt had gotten wet from the leak which caused the Belt to slip which in turn caused the Battery and Power Steering to malfunction.
A major Range issue is the last thing i need in my life right now.
