Clunking/Clicking Noise coming from drivers side
1 reading
8.8K views 11 replies 5 participants last post by  JSM
Hello everybody, I own a 2008 Range Rover Sport HSE...
Recently, a clicking/clunking noise started to resonate from the drivers side of the vehicle (can be felt from the drivers seat when driving)
The noise becomes worse whenever I make turns, or when I accelerate, in addition to making a complete stop at a red light then having to accelerate again.
Interestingly though, when the vehicle is driven on the highway, the noise will be greatly alleviated (if not completely cease altogether).
I went went ahead and brought it to my local mechanic (whom has worked on it in the past) Upon inspection of the vehicle he stated that more than likely it may be a laundry list of problems, with no definitive answers:
- Transfer case
-Driveshaft
-Front differential
Here is the link to the video; as soon as im making a turn exiting the highway. Hopefully this will help give an insight as to the root of the problem. 2008 Range Rover Sport Clunking/Clicking noise
#4 · (Edited)
Normally I would say that is a good question--however he has worked on my vehicle in the past. (No he did not charge me). I'm going to bring it in to another local mechanic that I've used in the past to receive a second opinion on. I've contemplated on bringing in to a dealership, however I'm well aware that is the most expensive route.
#6 ·
Are you saying that the rear drive shaft has given up the ghost--or are you referring to the vehicle itself?
I just spoke with the mechanic (the second one I referred to in the earlier post) he says it sounds like the driveshaft is bad so he is going to take a look at it tomorrow. (He specializes in European vehicles: BMW, Mercedes Range Rover, etc). I will however tell him what you advised me to do.
I will keep you updated!
#7 ·
He’s saying the same thing as me, probably rear drive shaft has had it. There’s a carrier with a bearing and a rubber boot/damper. The boot/damper wears out and then the drive shaft bangs around in the carrier bracket. It’s about an hour or so job to replace the drive shaft. Get a GKN, they’re the OEM supplier.
#10 ·
UPDATE: Unfortunately the worst has been confirmed; it is the transfer case, along with the front lower control arms (bushings are worn out). His quote with parts and labor is $2500--however the parts distributer he uses does not have any transfer cases for the Range Rover in stock. FML
#11 ·
Go to car-part.com and search. I found a transfer case local to me for $275 with 100000 miles on it. Why on earth would you even consider new, they are bullet proof from what I have seen and I'm not convinced it's to blame here either unless you or previous onwner ran the truck with mismatched tires for a long period.
#12 ·
I have to agree here. Of all the things that can (and do) go wrong on an RRS, the transfer case isn't typically one of them.
