Brake hoses
3.6K views 12 replies 4 participants last post by  charlie323a
LR recommend replacing all the flexible brake hoses every 6 years.
I’m planning to order the brake hose kit from Atlantic British. I think it is definitely overdue for replacement, still the original 15 years old brakes hoses.
Anybody here replaced their brake hoses?
just regular rubber hoses from AB.
I might even change all the original rubber coolant hoses before the winter.
#5 · (Edited)
I rebuilt some four piston Brembo calipers off a 2006 RRS and rebuilt my stock rear calipers using Frenkit components. Not very expensive and good quality, made in Spain if I remember correctly. I had to order two kits for each, one being the piston, seals and bleeders and the other being the hardware (front caliper: pins and clips, rear calipers: slide pins).
Replacing the various coolant hoses is always smart, but don’t overlook any inlets or outlets made of plastic. The outlet on my 3.0 TDV6 developed a split on a seam which was losing a surprising amount of coolant yet rather hard to detect at first. I’ll be changing my oil cooler/filter housing and breather plus all associated seals shortly. If the oil cooler on mine fails I can end up with oil in the coolant and/or coolant in the oil. Cheaper to do it as preventative maintenance with my upcoming oil change than the alternative.
#6 · (Edited)
I rebuilt my front passenger brembo caliper couple of years ago using centric pistons part# 146.46011 and seals 143.22007. All the parts fit perfectly. A lot cheaper than buying a new caliper.
I am OCD with preventive maintenance. Don’t want my vehicle to break down in middle of the road because I’m too lazy to maintenance the vehicle. Majority of the work I do myself. Thanks to YouTube.
#10 ·
I was talking about pistons, their website says they’re steel. Is that not correct?
For brake lines I’ll probably go with these:
Readily available here in Poland which is a big plus.
#11 ·
All of those "stainless" goods still depend on one family or another of reinforced elastomers under the braid to actually manage the fluid & pressures.
Upside is an expectation of improved protection against chafing abrasion, thrown gravel impacts or the like.
Downside is one can no longer see cracking, age, or exposure to chemicals degradation that might impair the "working" part of the hose.
My view is that they might be 'at their best' only in racing, hardball off-road, or the like, where one might expect MORE frequent replacement than usual. Not less often.
Dunno.
But "in general.."
A(ny) Iron (alloy) caliper body is best mated with steel pistons.
A(ny) Aluminium (alloy) caliper body, aluminium pistons.
Compatible galvanics and thermal coefficient of expansion considerations.
Not that it is a hard rule, nor always followed. Just lower-risk of disappointment.
