Are the deployable side steps worth it?
28K views 94 replies 44 participants last post by  AsL494
Never owned a Rover before but I do have a lot of older family that visit. Would the access height lowering be enough or would the deployable side steps be worth adding on? They are $4600 for the LWB but I've read dealers charging uptown $10,000 to install them after market.
I have owned appr. 7 Rovers. I never even considered having the deployable steps.
But when I purchased my latest (b/c it had 3d row seats and OEM tow packages), it also had deployable steps which wasn't even advertised -- turned out to be a nice surprise! Very, very nice addition.
They open with the door and shut with the door. Flawless.
One drawback: When leaning into vehicle to get something out, you have to stand on it, or the step will kill your shins.
#84 ·
That is the downside and they have had some reliability issues. I have them but really never use them. And if you are taller and don’t use them when deployed they will get the back of your pants or leg dirty. They probably would help with elders to get in. You can also turn them off and on when you don’t need them. If you live with ice and snow I would have them off in those conditions as they could get stuck.
#4 ·
They are one of my favorite features on the car. When deployed they seem to stick out farther that "normal" running boards and make it much easier to get in to the car without having to drag yourself over the seat bolster, especially in the Winter when one has the car elevated to "off road" height for the snow.
IMO, a great feature, but at >4k$, definitely pricey. :(
#10 ·
You can put them on at any time. We’re gonna pick up our car this Friday and discussed with the dealer for now we’ll leave them, and in a month or two we’ll see what we do.
  • Like
Reactions: Lev
#25 ·
I had the same thought about not "wasting money" to get the same steps as from the factory but just put them on myself. Then I watched a Youtube video on running the wiring, etc., to install the steps and said, "what a PITA, just buy them on the car". It would take me in my driveway at least a solid weekend to get that done.
#32 ·
Agreed. Deployables were conveniently unavailable to order for me at the time. Had to do it thru the dealership and even then was a hassle. They originally wanted almost 11-12k. Ultimately, I paid 7k in parts and 1k in labor. After the fact, I found out a shop that does that with aftermarket parts for 3k installed in the tristate area. Didn't even know that was an option.
Back to the OP, deployables or even fixed is a must on this car due to the height of egress. Sports model you can make do without imo. Regardless, get it if you have kids or elders.
#16 · (Edited)
We're also considering deployable steps on our MY24 L460. We've had the deployable steps on our L322 since 2015, and they've been excellent! Easy entry and exit, easy access to the roof bars / roof box, and the movement of the steps when opening the vehicle give an extra welcoming touch (y) . But, they require regular greasing to avoid disfunction (salty winter roads).
However, I'm a bit concerned about the deployable steps on the new L460: @BradleyScott mentioned here that the steps were noisy on his new L460. Anyone else have these installed and experience similar noisy steps?
#21 ·
I got the fixed steps on my L405 and now the L460. I like the way it changes the profile of the the trucks look and its less cost and maintenance. Just be careful where you park with the deployable ones because I know of people with LR and other trucks that got them jammed on a high curb or pilled up ice/snow and it was a nightmare getting it fixed.
#23 · (Edited)
I purchased mine off of eBay for around $1,000 delivered to California. Shipping was quick (maybe 7 days).
For those considering this modification/enhancement, I just installed them this morning completely by myself and had all four brackets installed in under 45 minutes. I did not use a lift, just put the vehicle in off-road high mode and was very easy to get to everything.This instructions that were provided are found on YouTube… don’t worry about the Chinese writing, your phone can easily translate it but you don’t need the words as the video shows everything (link below). Note - the motor arms go in the rear. Mounting the running boards took another 20 minutes. Connecting the aftermarket control module took under three minutes. You remove four 10 mm bolts from the trunk to get under the spare tire kit area and plug it into the existing wiring. You do not need to run any wires at all as the wiring is pre-ran from the factory from the trunk to the undercarriage. Reinstalling the undercarriage installation requires you to cutout a section to accommodate the motors but it’s easy with some strong shears and it is pre-cut from the factoryso you just cut along the lines.
Disclosure: the aftermarket controller deploys the steps when the doors are open and retracts when closed. This does not allow you to enable/disable the feature from Pivi like a factory option does. For that, I ordered an OEM control module off of eBay and am having the car coded for the option. My coder is out of town so it may be a month or so but I will post when complete. The OEM control module part should be VPLRP0486 for a 2024 RR LWB.
Install video link
#26 ·
Install video link
looks like a much easier install vs the 405. ....I had to remove the entire back end of the flooring to run the wires from the aftermarket harness to the module that needed mounted etc
