2025 P530 V8 engine
Tags
p530
1.1K views 12 replies 3 participants last post by  danny_162
I Have a 2025 Range Rover V8 with 5000 miles,
I noticed a significant shaking at a full stop idle RPM.
The car is at the dealership foe 2 weeks now.
They replced the engine mounts but it didnt solve the problem,
I asked them to check the oxygen sensors as well but they said its not causing the problem.
Any thoughts?
#2 · (Edited)
You’ve posted a question in the section labeled “No Questions Please”.
is it L460 full size Rangie or an L461 Sport so this thread can be moved to the correct section?
Edit: Moved to L460
#4 ·
So that's a full-sized one?
#11 ·
Hmmm, I did not know about a front engine shock as it is not typical. Could they be referring to the transmission mount perhaps? In any case, just let them fix it. Personally, I would be very curious and I would ask them to show me the mounts on the car as well as the bad mounts they replaced. Your car is too new for it to have 3 bad mounts unless it is a bad patch of mounts from the supplier. Good luck and let us know the outcome.
