Hello, looking for some help with my issue. So I picked up a 2004 gasoline powered L322 RR for a great deal. She's a real beauty, however she has slipping transmission when hot and P0732 code. Shifts through the gears just fine when cold but pretty quickly when it gets warm it will slip in 1st gear and drop to 5th gear throwing trans failsafe error. I have been doing research here and suspected the bad bearing and broken seal between the A and B clutch because the symptoms match that. So I ventured in and have removed the transmission. I opened it up and sure enough I see the bearing is in bad shape, but it appears I got to it quickly. Also, I see the broken seal clear as day. Here is my question. Can I simply replace this needle bearing and seal and put her back together? Can someone help me with the part numbers I would need?
I know I need new fluid and a new trans filter which I can pick up from BPutah, but what else and where can I source them?
Here are pics of my bearing and broken seal. Any help would be appreciated. Perhaps Phil could chime in.
Thank you to anyone who can point me in the right direction.
