The early 03-05 L322s used the ZF 5HP24 5 speed transmission.
I believe the 2011+ L322s came standard with the ZF 8HP70 8 speed transmission.
My question is simple: has anyone looked into, or actually completed a successful retrofit/upgrade and installed a ZF 8HP70 into a 2003-2005 L322?
I welcome your thoughts and comments!
I’m guessing, but I would not think this was really possible. Mechanical considerations aside, the newer transmission will be expecting communications with many other ECUs in the vehicle. None of these will exist in the older vehicle. It would most certainly be cheaper to buy a later model vehicle.
