I originally posted the message below in the new members section a few weeks ago but I thought it was time to introduce myself here in the L322 threads.
"My name is Jon and I've been a proud Jaguar owner for all of my adult life, currently on my 8th XJ, a 2014 5.0 Supercharged which I've had for 5 years now, still running strong at 126K miles or so. I've been a member of the Jaguar Forum under the same username for well over a decade now. I've joined your noble forum today because I've decided to finally get serious about giving the Big Cat a playmate. My wife and I are becoming more and more outdoorsy as we move into middle age, and we'd really love to use a Range Rover for what they're intended. This would be an entirely unnecessary third vehicle for us, and would only be used for inclimate weather, hauling stuff, and weekend fun. I'm trying to decide between a Mark III or a Mark IV, with the 4.2 or 5.0 engines respectively (I haven't yet learned all the model factory codes), as I'm very familiar with both, and I do all my own maintenance and repairs. I'll be reading through these fora trying to learn as much as I can before I come to a decision. I know I could not have been able to keep and maintain my Jags over the years without the immeasurable help of the Jaguar Forum, so I wanted to introduce myself, and thank you in advance for granting me access to the wealth of information here."
Well, I am now the proud owner of an 07 with the supercharged 4.2, Java black with black leather and cherry wood interior. It's got around 115K miles and pretty good service records. It's a bit of a diamond in the rough but I've spent the last week sprucing it up and getting some maintenance and odds & ends squared away.
Here's what I've done so far:
Things left on the to-do list:
-supercharger oil
-supercharger coolant pump upgrade
-Caldoofy intake tube
-transmission fluid change with mechatronic sleeve and bridge seal replacement
-might need to replace the front "upper" control arms, I can't quite tell the condition of the bushings
-replace the upper tailgate lock motor as its doing the 3 clicks and WD-40 hasn't helped
-replace the center console struts
-replace the non-functional reverse camera
-repaint the Brembo calipers
-various other little upgrades or mods here and there
Tomorrow morning I'll be going to Discount Tire to have a set of Toyo Open County AT3s in size 255/55/20 mounted, so that should be fun.
Anyways, glad to be here and I'm looking to getting to know everyone.
- The headlights were heavily oxidised so I cleaned them up with sandpaper and Meguiar's restoration kit. Once I did that, I realised that the projector lenses themselves inside were all fogged up. So I unhappily decided to take apart the housing, clean the lenses as best I could, then glue it all back together. Big pain in the rear but I had to do it.
- I replaced all the headlight bulbs with LEDs except for the signal blinkers.
- I replaced the fog light assemblies with new aftermarket units with LEDs
- I used Meguiar's Black Trim Restorer to clean up the exterior pillars, which were looking VERY tired. They almost look new now.
- Cleaned the MAF sensor
- Changed the front and rear diff & transfer case fluids
- AC was not cooling, so I evacuated the system completely and refilled. We'll see how long that lasts.
- cleaned and conditioned the interior with Lexol
- repaired the tabs on the grille and replaced the Land Rover badge
-supercharger oil
