1 - 1 of 1 Posts
Guys, here's an update with my X-mas lights (ABS, Parking Brake, TC). All of these lights would quickly flash on and off when I pressed in the brake pedal. They never stayed on just flashed each time I braked. Based on the rec's from some gracious users I replaced the ABS Accumulator and problem solved. I did get a low brake fluid warning fault. I just finished top off the brake fluid reservoir and drove it around the block a few times and the fault message has not come up. I will test it out on tomorrows commute.
It does make a noise/wine now like the motor/pump is continuously working....this sound used to happen just when I depressed the brake pedal. Now this wining noise seems to be on sporadically.
Brakes work fine but the wine is now happens when moving and not just when I brake.
1 - 1 of 1 Posts
