What lead to the replacement of the old battery?
Was the charging system checked to verify it was working properly?
Was the old battery load tested?
Was the new battery load tested and charged?
I can tell you that some independent shops will have batteries sit on a shelf for a long time. The batteries should be rotated with fresh ones, but sometimes the battery delivery guy doesn't always check. Interstate has good guys working for them, but a new guy could be slacking.
If you check the side of the battery for a sticker, this will indicate the year and month the battery was built.
You'll want one within the last 6 months, nothing really wrong with an older battery, but it must be recharged to full prior to being installed.
Older batteries will sulfate, and these crystals prevent the battery from fully charging. There are commercially available battery chargers with a desulfation mode.
So lets assume the new battery is fully charged, and you have a working alternator.
What is preventing the starter from cranking?
Weather can play havoc on a battery, you say the temps are above freezing.
Take out your multi-meter, and test the voltage at the battery.
What is the voltage reading? Should read 12.2v +.
Use the same meter but place it at the starter solenoid battery wire.
What is the voltage reading? Should read battery voltage.
Now get a friend to sit in the drivers seat and have him attempt to crank it.
You'll be testing for voltage at the solenoid trigger wire. May have a 50 marked on it, indicating terminal 50 (Bosch labels it like this).
With the vehicle in the start position, what is the voltage reading?
Anything under 10v and the solenoid won't engage.
This indicates a voltage drop, or a faulty starter relay.
A faulty ground wire could also cause the relay to flutter.
