Quick question for you guys. I have a 94 RRC with the 3.9L that needs head gaskets. I'm fixing it. The old Rangie is offroader so useable power and torque along with reliability is what I need from the engine. I would like more power.
I also have a 4.2L that could use a refresh/rebuild (stock rebuild, perhaps a better oil pump and a Crower cam?) that I was planning on dropping in my RRC sometime in the future. Stock the 4.2 are supposed to make 200hp and with hot cam, the one I'm looking at claims a good torque increase.
The question is, should I go ahead with the 4.2 rebuild plan or should I look for a 4.6 and build one of those?
I have never owned a 4.6 so have no personal 'seat-o-the-pants' experience to compare the two engines. I know the 4.6 is stiffer block and has cross bolted mains etc. and also the distributorless ign system to work around but do they not also have issue with the rear cylinder casting thickness? And of course i would need to find one worth rebuilding.
The 4.2 will be a drop in, I already have it sitting in the shop and I don't have a ton of money to spend (did I just answer my own question?) but if the 4.6 is significantly more powerful...........
Any thoughts or advice is appreciated.
Matt.
Matt.
