An FYI fr everyone. So, this past weekend after my car sat idle after driving fine for a few hours, it failed to start. it was turning over but just wouldnt start. It could not be jumped, the battery was fine. I had it towed ad the problem ended up being a $745 fuel pump. Just wanted to post this for anyone else having similar issues. The pump was getting electric to it but was not responding (electrically).
Unfortunately, this isn't as rare as one might hope. It does cost less if you are willing to do some dirty work yourself though. I heard mine making weird noises last winter... turned out my fuel filter was pretty badly clogged. I replaced it and it sounded normal afterwards (not really audible). I am hoping that the $60 filter replacement saved me from the $$$ pump replacement... so far so good nearly a year later.
I just replaced my fuel filter on my 03 at almost 80,000 miles and 8 years in service as preventive maintenance. Cost me $150, parts & labor, at my indy shop - we'll see if it pays off.
-Cliff
Does anyone know what the service interval for the fuel filter is?
RRPhil said:
150,000 miles according to the schedule for UK spec. vehicles : viewtopic.php?f=2&t=29990#p230577
Phil
And the service interval for oil changes is 15,000 miles, and the transmission is filled for life with no service interval for fluid/filter changes. Just sayin.
I was having a DTC that kept popping up that my indy mechanic thought might be coming from a partially clogged fuel filter, so it was part preventative maintenance and part a shot in the dark at that issue. So far, that particular DTC has not returned after the change.
Does anyone happen to know where the fuel filter is located?
There is a little access door where you can get at it... you can see diagrams in RAVE if you download it. A couple quick searches should get you what you're looking for. 150k service interval for fuel filter seems REALLY long. I would at least check it every 30k miles (more often if your vehicle regularly sits for days/weeks at a time), but there is some effort to get the thing out, and the part doesn't cost much, so I personally will just replace whether it needs it or not whenever I check it.
