1 - 12 of 12 Posts
Hi.
RR P38 zf 4hp 24
i have same problem:
"I have a 4sp ZF, when I select “D” the vehicle won’t move, when I select “1” the vehicle moves off. I can then select “D” and continue to drive normally. If I stop I have to start in first again."
Solutions for this problem:
"A sprag clutch has “inverted” and will need replacing. No further damage will occur if you continue to drive but you will need to select “1” every time to start moving. A rebuild is required to correct this."
But i dont' know - what part number of this sprag. Can you help me?
Is that part (see pic)?
Thanks.
I think you have the right idea with regards to the fix, but the picture you posted don't look like the right part. In fact, it doesn't even look like a sprag clutch at all.
I don't have the part number handy, but look for ZF4HP24 torque converter one way sprag.
Thanks, next info:
"I have a P38 Range Rover and when I pull off with hard throttle I get a bang bang bang from the transfer case area, why?
This is the chain in the transfer case jumping over the sprockets, needs a rebuild or at least a new chain. Please note, if this is ignored and you have an autobox, the shock of the chain jumping can often cause the one way clutch in the autobox to fail,"
I have same trouble with chain too. And i think, this trouble - cause of transmission damage.
Who knows how to rebuild chain? Any info? Thanks
Transfer case overhaul directions, photos etc are in RAVE.
Sorry, torque converter one way spag - like this?
Hi.
Thanks for answers.
My problem - front planet w/sprag.
When I opened the part on the lathe, wear was visible inside.How can I repair it?Is it possible to replace the sprag inside?
Any ideas? Thanks
Super Moderator
Possibly, it isn't only internet forums that get flooded with spam from Russia, we get phone calls too. Drop them an email explaining the problem and telling them what you need. Also don't forget you are 2 or 3 hours ahead of UK time.
1 - 12 of 12 Posts
