I am installing a sequential system to replace a single point lpg system
I need to intercept the negative wires to each of the injectors.
My initial thought was to tap into the wires in the ECM but looked at rave and found that it appears to have a common earth (A1-4) or am i reading this incorrectly?
Can someone confirm which is the negative side of C541,C542,C543,C544,C545,C546,C547,C548?
If it is the NO colours then i can tap into C505 at the ECM, if not i assume i will need to tap into each AMP connector at the injectors.
Any advice?
All done,
The negative side is the lower part of the diagram posted above.
It is easiest done in the ECM (which saves going in at the injection loom)
The lamba connections are also in the ecm as are the RMP pickup (Coil)
Nice and easy.
Would only take 1/2 hr if i were to do it again :D
