Hi All,
Mounted my new, secondary compressor over the weekend. Went reasonably well, pictures to follow.
BUT - the new compressor has two wires - red and black, ie no thermal cut out signal wire.
How do I splice these two wires into the connector?
I need to explain - I have used a spare OEM connector block with its three wires - green, black and orange. I know that I need to earth the orange one to fool the system that the thermal cut out is closed.
----- Which of the green and black is live? Is it the green one?
-----Therefore, the other black one would be negative.
------Do I earth the orange one to the car body, or can I splice it to the negative power cable?
I hope this is clear!
In your case and in mine with an aftermarket comp like mine.
Green = live
Black = earth
Orange = earth
Merci bien!
BUT - can I then join the black and orange together physically, or do I earth the orange and keep the black separate?
SpiggyTopes said:
Merci bien!
I joined those. No problem at all
Super!
Would you believe that I woke up in the night thinking about it?
If I connected the green to the orange .........
