Just got off the phone with the mechanic...
Apparently the thermostat heater failed, which overheated the wiring and damaged wires in the harness bundle... He said it may be possible to splice in new wires, but because there is so much wiring in a tight place it would probably be safer to replace the entire harness.!!
Fortunately he sourced a used wire harness for $1,000... which although is still pricey, beats the $2600 from a $tealer...
Does anyone know of a better price on the harness? Has anyone else had this issue??
-Christian
-Christian
