1 - 10 of 10 Posts
I have looked on Bosch / PIAA and others and cannot get a straight answer as to what blades (front and rear) are available for a 2017 (yet I assume all) L405's....I just replaced the ones on the Cayenne with Bosch ICON that were under $30 and took all of 30 sec to replace each one...
Anyone have suggestions and part numbers...
How are those ICONS? Any squealing or streaking or loud clapping when they transition direction at the A-pillar?
So far so good. I know what you mean about the "click" when they would reverse direction. I had that on my previous RRS. These new ones don't seem to do that.
Icons were OK for a short while. I changed back to the OEM blades in December.
Discussion Starter #10
Cut off is 2017+ where you must use the Factory blade only available at the dealer...it has a special mount with a button on top where the arm meets the blade assy...
1 - 10 of 10 Posts
