only my drivers side wiper functions. it functions perfevt in all settings, however the passenger side one does nothing. anyone encountered this issue?
The wipers have a connecting arm which links the two together.
Yours has come off/broken/worn, remove the panel below the window and you will see all.
While your there it's worth replacing the filter below the panel as it's usually broken up, also polen filters are in there which could be replaced.
I have a good used one if you need to replace it.. `)
